That would be my guess. Are you sunning the stock intake tube? If so, pull it off and check for cracks down inside where it is meant to bend. I've seen so many of them cracked there.
93 EGT stalls
Originally posted by carkrazed2005 View PostThat would be my guess. Are you sunning the stock intake tube? If so, pull it off and check for cracks down inside where it is meant to bend. I've seen so many of them cracked there.sigpic
Originally posted by carkrazed2005 View PostDoes it do it mainly when you come to a fast stop, hard on the brakes?Last edited by 1992tracerlts; 04-20-2009, 06:23 PM.sigpic
theory
As per stalling when clutch depressed...this leads me to follow the starting system electricals...which includes relays for the Electronic Engine Control & Fuel Pump Relay (thanks Haynes) as found under the center interior consol...any of which could be the "click" you hear...or others?
Just grasping at straws here...I feel your frustration.Later, Jay
