Head gasket????
    Had a blown head once..gasket fine and head and block fine...the real problem was a cracked water jacket into #3 intake port.
    On the plus side...I had overheated the engine 3 times and froze it solid once (I failed to test anifreeze after a summer of just adding water to a leaking rad). One tough engine!
    Later, Jay
      adding to the re-using headbolts thing, you CAN do it, its not advised but i have done more than one HG replacement with original bolts and both were 100% ok. but yes, definitely get the head checked while its off if you do plan to use the same one.
      '88 323 sedan, K-swapped..
        From what I remember, if I can remember correctly, my 91 GT head got magnafluxed somehow. I may not be remembering right, that was 10-11 years ago.
        This is my BP. There are many like it but this one is mine. My BP is my best friend. It is my life. I must master it as I must master my life. Without me, my BP is useless. Without my BP I am useless. I must drive my BP true. I must drive straighter than my enemy, who is trying to beat me. I must beat him before he beats me.
          Who makes replacement headbolts?
          91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
          95 Probe SE- Sold!
          The rest is bone stock.
            you can order some from mazda. a full set would probably be between $60-$90. they are usually $5-$10 a bolt.
              thanx for the info! I'll look into it.
              95 Probe SE- Sold!
                Spend $20 more and you can get reusable ARP studs
                  so your talkin about $100, roughly right?
                  95 Probe SE- Sold!
