Im boosting my 94 egt and I have to use a slim radiator fan due to my turbo inlet pipe being to big I'm gonna put it on the outside of the radiator and my question is if the fan is 2 wire and the factory plug is 3 wire which wires would I use to make it work on the outside of the radiator?
slim radiator fan
the 3 wire one is for the low and high speed fan relay cars. if your were running 2 you can actually use that still ,it should just be 2 powers and a common ground. im running one on front and one inside the bay, if i had that same harness id run each fan off each power and use the same high and low feature, basically it turns on the low at 207 and the high at 221. itll save power that way too, only uses one unless its really warm.... blue is the normal feed wire for the fan, and the yellow is the low speed one......92 protege lx-
94 protege lx-
yea thats what i was getting at, use the 12 in the bay as the high , and the 7 on front as the low speed. just take the grounds from both,connect them to the fan grounds, then take the blue from the plug and go to the power wire on the high fan, and the other wire left run it to power for the front one, and you should have the basic normal fan functions.....92 protege lx-
94 protege lx-
