Aight guys I need help on timing never done it before what pins do you bridge under the hood to time it and I was told to set it at 12 degrees so here is what I'm lookin at on the timing cover above the crank pulley it has a piece sticking out that has this on it |||10||||T| sorry guys best I could do but anyways where is 12 degrees?.......I'm probably with most things making this harder then it really is but I wanna get the timing right just so you guys know here's my set up vj20,cs downpipe,code b vaf,460 red tops,bp26 ecu,walbro 255 pump,and I do have a wideband from glowshift
timing on a bpt
Originally posted by Zexcort View PostAight guys I need help on timing never done it before what pins do you bridge under the hood to time it and I was told to set it at 12 degrees so here is what I'm lookin at on the timing cover above the crank pulley it has a piece sticking out that has this on it |||10||||T| sorry guys best I could do but anyways where is 12 degrees?.......I'm probably with most things making this harder then it really is but I wanna get the timing right just so you guys know here's my set up vj20,cs downpipe,code b vaf,460 red tops,bp26 ecu,walbro 255 pump,and I do have a wideband from glowshift
...^12
jump pins TEN and GND
94 Pro LX- 3-hole. Familia seats, Infini Corners, Familia Grille, Familia Rear Garnish w/Rear fogs EDM Glass headlights,
MSP Mazdaspeed Muffler,Mazdaspeed front strut bar,'00 Pro ES wheels, Neuspeed Springs,GR2s, MX3 wheel, MX3 Tall armrest
the T is for 0 degrees and each line is 2 degrees. so as caymen egt said go 1 line to the left of 101994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 Infiniti M30 Convertible - Traded in for Veloster
91 EGT - Junked May 2012
"Going to church doesn't make you a Christian like standing in a garage doesn't make you a car."
"I usually downshift when I'm near a Prius so they can hear me hurting the environment"
Late chime in....1st line above 10 is 12.
Mainly chimed in to let you know that my boy bomdoutscort has to return his glow**** wideband. His along with a few others(he said this) have had to be returned.1993 Protege LX-Midnight's shadow SOLD
well set the timing decided to take it for a spin I was told to get it at full boost and see if the wideband was close to 12:1 so I hammered it a lil wasn't what I was expecting kinda felt like it was holding back look at the wideband it says 10:1 or 10:9 or something I let off and it starts missing and won't hardly run had a time gettin it back home haven't pulled the plugs or anything but my luck it blew up damn it!
1994 Escort GT Turbo
were you going into full boost with a cold engine? thats never a good idea
lol you are running 460's untuned, thats why its running so rich. the gtx ecu is designed to run 360's.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
you probably just fouled the plugs
you could try using a SAFC to dial in for the larger injectors, turpro has a couple for sale right nowEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
well either figure out how or... idk. you can try adjusting the vaf but thats a real ball-park way of tuning things.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Apex should have files on there site you can download on how to wire it up. My safc2 didn't have directions. Just the safc neo did.1993 Protege LX-Midnight's shadow SOLD
