Check all the harnesses. They are old and the insulation can crack
causing wires to touch and short.
This may be the only problem you have to solve.
Make sure your spark plug wires are plugged into the correct sockets in the distributor cap.
If you are off by one plug you won't be igniting the right cylinder.
Try disconnecting the battery for 5 minutes and then reconnect it.
Turn the key again and check for the Check Engine Light.
If it still won't light you're going to have to pull the cluster
to change out the bulb.
Without a good bulb, the engine won't start.
Did you swap the ECUs ?
You really should not have to if both engines ran prior to the engine swap.
Just make sure that all of the sensors are connected,
the distributor is connected, and all ground straps are securly in place.
Worst thing you may have to do is swap distributors to match the ECUs.
Make sure you mark where the rotor points to
before pulling out each distributor.
Intake hose and Mass Air Flow HAVE TO BE CONNECTED for the engine to start also.
Let us know how far you get...
