Ok, posted this on FEOA, and got little to no responses, Figured you BG guys could help out.
1991 Escort GT Cayman 1.8L BP05
Ok, so, I changed over my alternator, just because I thought it needed changed due to the bearings giving out in it (yes I know the bearings are 40.00) and I changed it out. Well, it had given me NO issues until this point except for a squealing noise that I presumed came from the alt, because after running it, the pulley would be hot.
ANYWAYS, I said that so that I could say this: I've done everything short of testing it with a voltimeter. I've seen on FEOA people saying it could be an ignition switch, or an alternator (the one I replaced the old one with tested fine at Oreilly) and it has a new-ish battery on it. What am I missing here? It sat just about all day, I would go out there and crank it every 30 min to see if there was some sort of drain, and it fired right up every time without a hitch....
Well, I went 1/2 mile up the road to the cigarette store, grabbed me a pack of Newport Non-menthols, came back outside, drove home, parked it (5 spd) and cut it off. I tried to cut it back on, and it would turn over, but was extremely SLOW, and after turning the key back and trying 3 times, it wouldn't do squat.
What to check without a Multimeter? I can rig a test light and base it off of brightness at the bulb, but what should I be looking for? Checked the alt, swapped it out for the previous one, charged the battery all night last night, and still.... NOTHING. I'm getting aggravated and irritated, because it seems like everyone is questioning my knowledge on the car, and on FEOA (not bashing here btw, love them guys!) It seems like nobody really knows, because I have 100 something views, and 5 replies and 3 of those were mine. SO, why not come to the Mazda gurus and try it again and see if I have any luck.
In advance, thanks! I highlighted the major points of concern in bold and italic, so that if you were just trying to figure out what my problem was and not listen to me rant, it'll be easier for you.
JD
JD
