Hi everybody, I am in the middle of a swap with my wagon. Donor car is my '93 EGT MTX. Here is a link to my FEOA thread for past updates---> http://www.feoa.net/threads/my-1996-...eadline.81482/ from here on I will be updating both forums. :D
1996 Wagon -BP Swap/build
1988 Mustang LX hatchback *in pieces*
1991 Ford Escort hatchback mtx *scrapped*
1991 Ford Escort LX Wagon atx *SOLD!*
1993 Ford Escort GT mtx *in pieces*
1996 Ford Escort LX Wagon mtx *rebuilding*
1997 Taurus SHO *in pieces*
2000 Contour SVT *mothballed*
2000 Buick Century Custom *wrecked in Junked*
2002 Ford Escort ZX2 mtx *SOLD!!!(THANK GAWD I HATED THAT DAMN THING WIH EVERY FIBER OF MY BEING)* -
welcome aboard!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
THANKS FE3-323! UPDATE!!!! I got the rear floor cross member and lateral links all painted up, I just need to press in the new bushings. By the way I forgot to mention that I ordered the front crossmember to subframe insulators from this guy--->http://cgi.ebay.com/ws/eBayISAPI.dll...m=321119195791 they are an exact fit. Anyways I have half of the underbody painted with Rustoleum Undercoat--> http://www.youtube.com/watch?v=hEz4XMw261E . I will finish that when I get the rear end done and flip the car around. I cleaned up the gas tank and discovered that I need new hoses. I did run into a little snag; I have a dropped shifter . I will deal with that when I get to the front end. I did forget to take pics my apologies, I promise I will get them up tomorrow after work. In the meantime stay healthy everybody.1988 Mustang LX hatchback *in pieces*
i preferr to run screws through the shifter outer & part way into the inner as a way to hold it up. that and filling it afterwords with polyurethane from a caulk gun seems to work out as a permanent fix---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Welcome91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
THANKS GUYS! gas tank is installed, the strap bolts are M10-1.25, the rear floor crossmember is installed and those bolts are M10-1.25 x 30mm with a lock and flat washer. I was surprised to find that these bolts are grade 8.8 . I ordered some grade 10.9's from the internet but in the meantime I installed yellow zinc 8.8's from the hardware store. Through this whole restoration project I have learned that the suspension bolts are very uncommon. No one carries extra fine bolts in a high grade or flanged. I have had to special order almost all of them. At this point I am going to tackle the dreaded lateral links to spindle bolt. Wish me luck1988 Mustang LX hatchback *in pieces*
heat and a BFH are your friend lol, gl man-Jack
I ran into a little snag with the Addco #2065 "rear performance" sway bar kit . The supplied brackets do not have the correct geometry and the supplied poly bushings are too big to fit in the oem brackets . I did find that the new Addco bar fit in the oem bracket with oem bushings. I decided to grind down the poly bushings and use the oem brackets. They turned out perfect and only took a few minutes to fit. Now the rear lateral link to spindle bolt ...well I am at a complete loss at what to do. I tried soaking it in PB for a few days, I tried using CRC Freeze off, I tried using my press and ruined the adjustable link in the process, and I tried torching it with Mapp. Although I am pretty sure Mapp isn't hot enough, nevertheless I went through a whole bottle. I tried hammering it, I tried using a combination of impact gun and one of the above, I tried good ol' fashioned vise and breaker bar (I am 6'1" 290 lbs) and I tried praying. I don't know what to do, I REALLY want to get new bushings in there :\1988 Mustang LX hatchback *in pieces*
when i went to do mine i went through the same process . then copped out and bought a set of spindles with no bolts lol .. something i was about to try though was to grind the head of the bolt off and use a large nut as a spacer ( or several washers ) and try drawing the bolt out through the threaded side .. you might get lucky
where did you get your bare spindles?1988 Mustang LX hatchback *in pieces*
I had the same issue with my Addco bar, used a dremel to shape the bushings to fit in the OE brackets, worked like a charm-Jack
I can source spindles. You need disk or drum? I actually have a full rear disk setup, and the energy suspension bushings to fit the ttl's as well as a spare adjustable ttl, if you want it all.Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
