man, the car is looking good now... hope you don't forget the proty.
btw, a question on the mx3's moonroof, is that similar to the protege's roof assembly in anyway? just wondering since i can see the window slides over the roof and not into.
naw the mx3 sunroof is shaped differnt and is a little bit smaller.
Update
I worked last night and today to replace the rear valve cover gasket. Whew...what a job! The removal and installation of the intake manfold is a tedious project. There are a lot of ****ing vaccume hoses, coolant lines, and electrical connections to remove from that SOB. lol...Im just glad it's done, and hopefully the oil leaks are all taken care of now. I didn't label anything I removed, but luckily I have a good memory and managed to hook everything back up where it was supposed to go on the first try. The car took a few tries to fire up initally, I guess it just needed to build up fuel pressure. Runs fine though, took it around the block and everything seems to be ok. I still have a high idle though....Im guessing there is a vaccume leak somewhere.
Now all that is left is to replace the axles and the alternator/belt....hopefully.
ah mark, u know what, me and a buddy raced in his GS, we both had the same mods he had a y-pipe intake, and i had beader - intake exhaust on my pro. And i left him everytime.. Now sell the mx3 and buy another portege!!!!!!
BTW, i thnk i have a gs front lip available if u want it, but its teal i believe..
