is the miata B6 ecu a plug and play switch to a 1995 MX3?? i want the 7000rpm rev limiter and i believe the miata ECU has more aggressive mapping for marginally more power and a better power band, is this possible to swap the two?? thanx
B6 Ecu
nope, the mx3 had a distributor the Miata doesent.
i thought about doing that, but it would require swaping the wiring harness, along with all the sensors. you would get alot more bennifit from swaping to a 92 mx3, or a Pro LX harness (which is a better fit cause of the VICS), and swap in a BP10 ECU, and MAF with all the sensors. and you would have a redline of 7200 RPM. and it would probably be cheeper.Josh
95' AWD MX-3 RST - Still a work in progress
05' MS RX-8 - Needing some love in the form of a new motor, soon to be FE3 powered
Work Log - http://www.wihandyman.com/forum/showthread.php?t=53776
Cardomain Page - http://www.cardomain.com/ride/408020
Face Book page http://www.facebook.com/pages/Mazda-...37983472959216
