if our bore is bigger then the means the area to fill is larger if you take that into account then flat top valves would have a smaller affect... if the bore was smaller then the flat top would have lager affect... its like division if you if you have 1/3 and increase the 1 to 1.1 that would have a larger affect tahn if you had 1/4 and increased the 1 to 1.1, make sense? Also our valves do not dish in very much at all...
Coming Soon (hopefully) MX-3 GTR
In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
The engine is almost done!
Installing the ARP head studs
Glassbeaded and clearcoated Oil pan... looks brand new
A few small pieces and this engine will be done!!!In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Tasty!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
hawt!!
i think i am going to go with blue for my valvecover as well... a bit darker though. hmm....
it is actually a bit darker than in the pic.... not sure why but it looks a little washed out... i might go with red adjustable cam gears... do you guys think those will be a good investment along with everythign else i have and have planned?In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Originally posted by projectmx View Postit is actually a bit darker than in the pic.... not sure why but it looks a little washed out... i might go with red adjustable cam gears... do you guys think those will be a good investment along with everythign else i have and have planned?
And everything looks awesome Tim!
thanks
and does the yeah mean the adjustable cam gears are worth the $208?In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
you're going all out on the motor, you should spend that money to help with tuning and getting all the power you can out of that engine. i would say yes, it's worth it.Create your own VB Gallery here.
They are worth it.. If i was you id get the "clear" or "blue pair it would much better offset your motor---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
the blue probably won't match the valve cover so it would be taky... so its either clear or red.. i was leaning to the red cause aside from the blue valve cover most everything else will be clear or black so i thought it might add a little more splash of colorIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
two different shades of blue isnt a bad thing, unless they are close and it looks like a crappy match job.
i've got some blue anodized parts (wastegate, eventually cam gears, etc)... and i'm probably going with a dark/navy blue valvecover. looks good in my mind at least lol
oh yeah, and i dunno how i would feel about red cam gears on your motor... red, silver, and blue is too patriotic looking for meLast edited by therieldeal; 12-14-2006, 07:31 AM.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i suppose it is a litlte patriotic... not that it's a bad thing personally... but i suppose it could end up looking corny.. and i'm pretty sure the blues is one of those close but not quite thingsIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
ah, thats too bad about the blue color . yeah i have no problem with patriotism either, but having a mazda with patriotic colors under the hood might look a little funny heheEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
