Ok I just bought an mx-3 about 2 months ago! I'm currently working on body work....... Anyways I'm was thinking about going turbo but I want to go all motor or nitrous since I already had a twin turbo car (400hp stealth TT). So you guys have any idea what I can do to increase the hp? I'm going to take out the A/C & powersteering for less stress on the engine and less weight.
All motor 1.6L
i agree, swap the B6 out for a BP... its much better platform to start with .
-jonEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
nothing really, it is very very similar in design to the BP. many parts are even interchangable.
but why would you intentionally start out with a smaller displacement engine
just to be different, I don't want to go with the whole swap deal......pita I hate swaps ! I just want to make some power out of an engine that seems imposible to make power out of. I found an engine kit that will bump up the compression to 10.5:1 instead of 9.0:1 do you know where I can get cams for this engine? I was thinking about 1st gen miata cams, but not sure if they would work.........
a bp swap would be easy... it all bolts/plugs in. plus you could then put high comp pistons in the BP and have a real nice amount of power . higher comp in the B6 is probably only going to bring you up to around stock BP levels.
your call though
miata cams should work IF the distributor is on the same cam as the miata. i heard they swapped that around a bit with the B6.
-jonLast edited by therieldeal; 02-21-2007, 12:04 PM.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
they do but they still use a cam angle sensor, which bolts in just like our distributor. in fact our distributors use the same cam angle sensor inside.
Originally posted by therieldeal View Postnothing really, it is very very similar in design to the BP. many parts are even interchangable.
-jon**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
well still, idk if its really worth it. Theres a bunch of Miata stuff for that motor, but I still say the BP is a better platform to start with. Hell I got mine for $240 and it only has 67K on it! The swap is virtually plug and play (some exceptions) I say leave yer motor in and build an all motor BP. when its done, do the swap. Just my .02
Originally posted by Tazman2 View PostI thought the B6s are tons weaker then the B8s/BPs!
