never had a BP so im going to go with a biased answer of all motor KL. clean engine bay, and still quick.
What to do!!!!!!!!!
FE3>BP however it depends- if you can get a FE3 get it!! if not. then a JY motor
clean the outside off & soak the holes with ATF- rotating it every so often
a JY BP will be cheaper thats the only plus i can think of---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View PostFE3>BP however it depends- if you can get a FE3 get it!! if not. then a JY motor
if you run E85 i suggest replacing the rubber lines from the tank/hard lines -hardlines/fuel rail with multifuel rubber hose (napa carries the stuff)
anyhow im FE3 biased im pretty damn sure there was a 8 bolt flywheel/clutch G series compatible you could use with a Kia FE3(but youd be @ a lower compression 9.2/9.4:1 memory is fuzzy) still higher then the BP
i know you have access to fabricating manifolds/such i can give you advice in that department- you have my #---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postif you run E85 i suggest replacing the rubber lines from the tank/hard lines -hardlines/fuel rail with multifuel rubber hose (napa carries the stuff)
my friend jon used an escort gt clutch in his kia sportage (fe3n)-Jack
Ill buy them cams if your goin FE, lol.AWD EGT BUILD http://www.clubprotege.com/forum/sho...-AWD-EGT-Build
I say jy BP. That will get you back up and running asap, if that is what you need.Create your own VB Gallery here.
