all he did was replace the clutch kit, everything else was from the Kia Sportage.
What to do!!!!!!!!!
what? f2 non turbo trans? its a friggen Kia Sportage man!! Idk what trans it is, some 4wd gseries probably, i'm just telling you the Escort GT CLUTCH KIT in his Kia Sportage, which comes with the FE3N in it!!!!-Jack
Originally posted by bp_turbo'd View Postu dont like your v6?91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by Mazda_Powered View Postwhat? f2 non turbo trans? its a friggen Kia Sportage man!! Idk what trans it is, some 4wd gseries probably, i'm just telling you the Escort GT CLUTCH KIT in his Kia Sportage, which comes with the FE3N in it!!!!
you just have to make sure that ring gear on the flwheel is going to be in the right place to mate with the starter. if the diameter is a little smaller you can always just get it custom done to work. I did that with my old Hyundai when i swapped in my 2.4. I used a flywheel and clytch from an awd talon. had the ring gear removed from my original flywheel and installed on the talon flywheel with a sleeve in between it. worked great and it wasnt expensive to get done91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
you should be able to use a kia starter?-Jack
its highly unlikely that there will be a ringgear-to-starter mesh issue. as a failsafe, count the teeth---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
no i don't---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I don't really understand why anyone would want an FE over a BP.
Best motor eva!!
IMOAWD EGT BUILD http://www.clubprotege.com/forum/sho...-AWD-EGT-Build
Originally posted by mx-3_4evr View PostAn FE3N can handle 300+whp just fine with stock internals, so more reliable that a BP. Plus you can stroke it to a 2.3L
I have never blown one and i've had like 30 egt's, lol.AWD EGT BUILD http://www.clubprotege.com/forum/sho...-AWD-EGT-Build
yea the only way i'd go FE3 is if made it a 2.3L with the h-series trans, til then BPs for me!-Jack
FE's suck!!
Ha ha, jk.
I will take them cams though if you decide to sell.AWD EGT BUILD http://www.clubprotege.com/forum/sho...-AWD-EGT-Build
