I still think you're working on an empty block lol, jk jk....post some pictures tho!
2011 mx-3_4evr's turbo MX-3!
^lol I will.....soonToday I got the walbro 255 intalled, but not without a fight with the gas tank screws. I ended up braking 2 into the gastank, but I think 4 bolts will hold along with some gaket maker
Next is to fix the steering rack, it has some play in it. I think I know whats wrong with it.
ya those tiny bastard screws are horrible once they get a bit or corossion or rust on them. My old BGs I never bothered trying to remove them, I took the ez-out screw removal to all of them then replaced them haha.
IT should seal if the sealant you used is gas proof tho lol.
Steering rack play? Inner tie rods? or those new? don't forget to check the column separation joint (where the column disconnects from the steering rack) as those bolts have been known to back off.-Jack
ya ya ya...same old story about the pictures...lol-Jack
Originally posted by Mazda_Powered View PostSteering rack play? Inner tie rods? or those new? don't forget to check the column separation joint (where the column disconnects from the steering rack) as those bolts have been known to back off.
1st, the bolt that you mentioned was loose, I managed to installed it backwards so it wasn't tightning lol.
2nd, the bottom nut of the rack needed to be tighten as well.
Everything was put back together with thread lock. I also blocked all the holes that ran fuid to rack. Now it's like a brand new one
I also fixed my ebrake (new calipers) and installed new rear bearings. This car is going to be awesome to drive with all these brand new/fixed parts!
As for the engine, I'm waiting on the cylinder head to be finished. I also need to buy the clutch, and finish my 3" exhaust. I have a lot of work ahead still
list is getting shorter tho man!
Glad you found those pesky bolts, I think it was Jon Reil who had this issue with his EGT, would spin the wheel but the steering rack would stay put lol.-Jack
in all honesty, the quality of the ebay gasket is superior to the felpro's i've seen for the BG---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
OEM Mazda are supposed to have revised gaskets for the BP now. Much different than ebay/felpro quality, as I find no real difference between the 2 asides from cost.-Jack
