Ok I am doing a turbo swap on my mx3 and i am trying to run the pipe off the turbo for the mas air but its hitting my lower motor mount. And i am running the vj20 if that helps guys. Just seeing if anyone has ideas or is there only one way to do. I searched for it but couldnt find anything so far yet.
mx3 turbo
there are 2 types of front mounts, one with a light recess in it to clear a pipe. i suggest cutting the front mount in order to clear a pipe.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
either source out a GTX/GTR front engine mount bracket, or you can get this http://www.siliconeintakes.com/produ...1e315c30846d33
and run a 45 degree pipe off that to your air meter.
I run the reducer coupler, check out my build thread if you want, tons of pics of my FMIC setup....just can't recall which page LOL-Jack
