some good info there but a long read to find out he didnt finish..
so far the power steering lines are a lil goofy but they should work..
being the v6 gotta mess with the fuel lines a bit going to switch over to the GTX fuel rail that came with the motor for some better fitment
you need the EGT power harness or i guess any 4cyl power one for the starter/alternator plugs to be right but you can just unplug all the headlights and other non motor plugs from the fuse box and the gs ones fit in their place no problem.. just swapped over the whole bracket with the coil n all
Engine/trans, radiator/fan to go in tomarrow hopefully do the rear brakes and figure out which linkage to use..
