Marc's Sooty v2.0 - Autozam AZ-3 B5ZET
AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
Mx-3 2.5 V6 Turbo 291 BHP 251 lbft @ 8psi - Retired due to rust and back at uni
View Worklog
damn thats purty---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thanks! I've now redone my intercooler piping into just two simple pipes all TIGd together :D Photos will follow when I actually get an hour without rain.AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
anxious for photos of the pipes---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
ditto ^^ looks real clean so far!-Jack
Cheers! I've only 800grit wetsanded, may polish, may powdercoat. It's all nice 'n' light alloy TIGd together. Battling with a crap idle control valve at the moment. It works for a while then seemingly randomly stops working, idle shoots to 1700 and then next time I get in the car it works again. Maybe doesn't like my megasquirt settings. May just block off the valve.
Intercooler piping (re)done!
One piece :D
Turbo to IC
3" downpipe yo
View Worklog
Thanks mate. Well if you need anything butchered on come up haha. What did you end up doing with idle?AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
great to see it all together! i bet its a blast to tear around town in---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Sure is! Thanks!
Been working at other projects atm but went to a meet for a while yesterday:
JDM side skirts on yo!AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
looks good!! should get that rad hose off the IC piping though lol-Jack
Ahh the rubber strips were the gift of a previous owner! I removed one today, takes about an hour arghhhhh. Car wants a respray. Thanks! Skirts seriously transform the car.
Cheers Jack yea haha probably should. I gotta sort out a stuck lifter first. Going to do timing belt and water pump whilst I'm at it.AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
Yesterday I replaced:
Timing belt and pulleys and spring
Cam seals
Crank seal
Water pump
Also stripped and cleaned 8x intake hla
It was all a pleasure to replace! Very easy on this engine
It still didn't cure my HLA tick but that's because that turned out to be an exhaust gasket!
There's still a bearing sounds a bit whiney, maybe alternator.AZ-3 1498cc B5ZET! EVO 8 turbo and manifold, 5 stud swap, SSR Type C, DIYPNP seq Megasquirt
View Worklog
Pull the alt belt and see if it still has the whine to it, it'll run on battery power, but I suggest not to let it run long lol-Jack
