engine harness and ECU from a V6 powered mx6/626 lol
My 626 mtx swap.
jack. 90% of the harness issues mazdas have are burned ground wires. the melted portion should be inspected carefully. I highly reccomend cutting out the burned traces from end to end & replacing them entirely.
Or.... just buying a new harness
PS whyd you sell the BG againsorry man -had to
trust me, if I knew the 626 would be giving me so many electrical issues, the thought would have never crossed my mind!
Would have scrapped it when the ATX fried lol-Jack
Well made out well at the wreckers today, got a complete 95 V6 MTX harness and ECU.
I'm looking to see if I can use it with my 93 distributor that's wired for the HEI coil-Jack
is the ECU the complication? or the harness?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
the ignition system, mainly I think the external coil setup.
I wired it in the same as it was on my 93 distributor (had pigtail for reference) but no go. Then I find out that 2 wires on the 3 pin plug are switched in 95, so I did that aaaand nothing yet again lol.
I've seen a few diagrams that had cut the wires leading to the 6 pin plug, so I tried one at a time, and nothing.
tested the coil, and the ground is good, but I'm only seeing about 10v.
Does anyone know which way our BG coils are setup for + and - ? I can't recall if the left pin is power, and the right pin is ground (looking at the sensor)-Jack
cool I can find it man, thanks!!
edit: well I can't find it lol-Jack
oh it wasn't the distributor when I had the original engine harness and ECU, there was a short in the harness somewhere and it melted lol.
Running a 95 harness/ecu now though, and it's solid.
plus I already converted HEI & external coil about 3+yrs ago lol...just trying to get the wiring correct, but I finally believe I have! Took a bit of time, but my friend Aaron came over with some ECU print outs for 93 and 95 to finally put and end to any speculation the wiring was different.
I have determined that the 3 pin plugs colors are the same, as well as their functions.
Black/white = power wire- HEI port B, then to the positive side of the coil
Green = Tach Sig IGN - HEI port C w/ resistor inline, then to ground side of the coil
Yellow = Tach Output - HEI port C
While only the end wire of the 6 pin plug is used for a trigger wire (which is yellow in my case) goes to HEI port G
this should hopefully fix the problem...need to pick up a soldering gun as mine is shot, and Aaron needed his back LOL-Jack
well I just came back from soldering my new HEI harness in and it still doesn't start.
got a used snap-on soldering gun which works awesome! Just going to get some help now to test some wires;....-Jack
well I'm nearing the end with things I can look into myself, my electrical knowledge only goes so far.
i
I'm just puzzled that I'm not getting 12v to the 6 pin distributor plug, but the 3 pin coil plug shows 12v for all 3!
So the supposed "trigger" wire from the 6 pin plug, isn't doing a damn thing! Ain't triggerin' shiiiiiiit-Jack
I have a lead on a 95 distributor to match my harness and ECU now...but I'm contemplating on getting it since I don't understand why I don't have any voltage at the 6 pin plug with the key on...wtf?-Jack
