what is the best type of oil for my protege..
    I need an oil change and I need to know what type of oil is the best for my car. I drive a 2002 Protege ES. Any tips will be appreciated.
    Synthetic. Pick one, they're all pretty good. I've been using royal purple 10-40, or Redline.
      Any Castrol or Mobil product. Ive got 243k on my pro and ive run only castrol and in the last few years mobil synthetic. No smoke, no noise..... runs great
      90 LX PS/AC delete, pacesetter header, gutted cat, resonator delete, full 2 inch exhaust. rx7 VAF, home made intake, F&R ebay STB. 18* timing.
      200lbs in weight reduction. old school bmw 318 wheels
      http://www.cardomain.com/id/gascanexplode
        i run valvoline in my normal cars.... never had any problems
        mobil one in the turbo car
          I run 10W-30 Castrol GTX dino oil in my 94 LX. It runs like a top and gets good mileage, so I keep using it. I also use Purolator filters almost exclusively.
          I run Shell Rotella 15W-40 in my brother's 94 VW Golf, as anything lighter seems to make the oil light come on. I don't pretend to understand why it needs the thick stuff to keep oil pressure up, but it makes for a happy ABA.
            It needs the thicker stuff cuz there's too much tolerance in the oil pump or bearings. The thicker stuff oozes outta the gaps slower so there's more pressure. Whatever works, man!
              just what I was looking for ! thanks guys ... o yeah i can't do it myself I got to take it somewhere. for one I never done it. 2 I live in an apartment so no garage....
                if you go synthetic, stay synthetic. I myself used to use pennzoil
                  yea, vw's are supposed to use heavy oils. i think that's actually what the owners manual calls for on my brothers rabbit.
                    ive never had any problem switching back and forth..... on multiple vehicles...
                      i would definately recommend extra virgin olive oil. dont use any of that skanky olive oil
                      "Beer is proof that God loves us and wants us to be happy"
                      -Benjamin Franklin
                      i wish my grass was emo, then it would cut itself
                      -dedicated to sling blade, aka, meltdownsky
                      this is a horrible trick and should be deleted immedately - wheresthericego
                      http://www.wihandyman.com/forum/showthread.php?t=35130 - BWAHAHAHAHAHAHA
                        the skank adds character
                          what happens if you get low on skanky oil?
                            mobil1 10-40 synth, mobil1 filters only
                            It has penzoil synth in it now 'cause I had jiffy lube change it in a pinch before a road trip. the cars the same as with mobil
                            95 ES
                            05 S60R
                              you'll have to run out to your local lindsay lohan and get some more.
                              -Benjamin Franklin
