Got it out, dusted off the beast and took her out for a few hard pulls, broke the exaust, all for you guys here on youtube! Enjoy!Follow the link for pics! ...
can't see the motor, but it sure has the right sound
check out the 8 inch wide 14 inch wheels... "Very Nice"
I would not call this one a swap, but a pure fitting and waste of money.
And i prefer to not see under the hood !!!
But sure it's a KL.
I'm not sure where you're coming from on this, but to me getting a KL series engine running and driving in a toyota is a hell of alot more impressive than any of the plug and play engine swaps that normally grace these forums. Including swapping a K8 for a KLDE/ZE. It's no show piece but give the guy some credit.
its like putting a chevy small block in a miata. takes skill to do that, for that reason he gets props.
No car! I soldz it. Now I have a truck. I like it, but apparently it has a hard time keeping up with a slightly modified 4WD protege with half the hp. Neat.
neat swap, too bad the corolla isnt in better shape, maybe a test bed for another clean shell
