Just placed an order
Metric High-Speed Steel Hand Tap Taper, 12 X 1.5mm, D6 Pitch Dia, 4 Flute
Thread Repair Hex Dies Right Hand, M12 X 1.5mm, 1-1/16" Width Across Flats
Type 302 Stainless Steel Extension Spring 1-1/2" Length, 3/8" OD, .048" Wire Diameter, packs of 3
Type 302 Stainless Steel Extension Spring 1-3/4" Length, 3/8" OD, .048" Wire Diameter, packs of 3
Heat-Resistant Cobalt Steel Jobbers Drill Bit 1/8", 2-3/4" O'all Lg, 1.4" Drill DP, 135 Deg Point
Heat-Resistant Cobalt Steel Jobbers Drill Bit 3/16", 3-1/2" O'all Lg, 2" Drill DP, 135 Deg Point
Heat-Resistant Cobalt Steel Jobbers Drill Bit 1/4", 4" O'all Lg, 2.3" Drill DP, 135 Degree Point
Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M12 Size, 100 mm Length, 1.5 mm Special Pitch, packs of 5
Plain Steel Type A SAE Flat Washer 1/2" Screw Size, 1-1/16" OD, .07"-.13" Thick, packs of 55
Metric Extra-Thk Black-Oxide Stl Flat Washer M12 Screw Size, 22mm OD, 2.5mm-3.4mm Thick, packs of 10
Thats right, 55 1/2" washers. If anyone needs some please let me know!
I wish I was not deploying to Afghanistan next week. I would like to work on my BP for the first time in at least a year.
