my first mod was the wheels lol
what was your first mod on your car
my first mod on my 96 sephia was, custom cai, second, front strut bar with reset timing, and last 17" with new 205-40-17. now i have a bunch of things that i will be doing soon like eibach springs, new struts and lots, lots of other things. now my crapy camera is not helping me atall, all pics coming blury, so shopping for better unit so i can post some pics. (OH MY GOOD I FEEL LIKE I HIACK JACK THIS THREAD) SORRY!!!!!!!!
old neon was the sri, the protege was a custom intake, the 323 was a built turbo motor lol did everything at once on the 323Originally posted by 90prtegehave you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!Originally posted by TurproFk the family. Drugs and hookers take priority first
bpt323: broom break
CRZbrussian: that sux
CRZbrussian: get swifer wet
CRZbrussian: ****s aluminum
first "mod" on the 323 was a custom exhaust and highflow cat due to the original being clogged.
the fist thing I had to do to it was body work from a drunk soccer mom dragging down the side of it"Discontent is the first necessity of progress."
It was all over once I put rims on Anika. After rims... i needed a bigger engine... and i was hooked.When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
1st mod on 323 was a rx7 maf with cone filter.
first mod on pro is fully stripped light weight reduction....... problem is the engine was part of it.......lol
Originally posted by minnesotapjCost of your fancy German built sports car $35k
price of your fancy sun glasses to match your German built sports car $200 dollars
Getting beat by a second hand 20 year old Japanese 4 door... Priceless!The only bummer about the world ending is that you can't turn to the person next to you and say "WOW! Did you see THAT?!!"
My first on the pro was a custom exhaust. I didn't get hooked till I found this site. Now I'm just gettin started!
See, you guy's are a good influence! lol94 pro base model, all synthetic fluids, s/r struts, front & rear ebay upper strut bars,front & rear tie bar, ZX2 1" front swaybar, EGT 21mm rear sway bar, custom delrin endlinks front & rear, custom delrin rear swaybar mount bushings, EBC front blanks & redstuff pads, CS ss brake lines & dot 4 fluid, big drum brakes in rear (from ZX2, free parts), 2.25 custom exaust w/magnaflo oval muffler, 4-wire o2 sensor, custom ram-air, 4-wire BP tb, MSD super conducter plug wires, MSD Blaster SS coil, NGK iridiums,OEM weighted shift knob, ebay short shifter, bronzoil bushings, CS ss clutch line, custom air splitter, mx-3 recaro drivers seat, EGT foglight switch, 35w 5000k hi/lo hid's
soon:
lightened flywheel & clutch; in garage,
Miata Daisy's; after new tires
pacesetter exhaust.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
MP3 Strut Tower Bar kit.
Custom mild steel heat shield when my stock muffler tip broke and started to melt my bumper.1990 Protege 4WD
1 3 5
2 4 R
