I AM the seed of the chosen creed you don't see too many like me.
How sore is sore enough ?
good call but what show?mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
major bonus cool points for pox. man i miss that show. back to topic tho.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by Meltdownsky View PostDamn Mark, 1.6 miles like to have kill me today [1st day of adding running/jogging to rest of routine], beautiful day to be out tho...oh yeah, I worked 8 hours before rushing home to do all of this.
i usually run 7.2miles of mountainous pennsylvania roads home from work everyday. 9.0-9.5 (not sure exactly) miles if i have to take the long way and stop at the bank. try doing that without stopping. it damn near kills me. when you run, push yourself a little harder everyday. if you can run 1.6miles without stopping, try 1.8 miles the next day. you have to push yourself just the extra little bit to get better at it. when i first started running, i could only run like 4miles and had to walk 3miles (it was run a bit, walk a bit, run a little, walk a little), then i gradually increased it to where i could do the whole thing. it went from running 4miles to running 5, then 6, then 7. YOU CAN DO EET!"Beer is proof that God loves us and wants us to be happy"
-Benjamin Franklin
i wish my grass was emo, then it would cut itself
-dedicated to sling blade, aka, meltdownsky
this is a horrible trick and should be deleted immedately - wheresthericego
Originally posted by Jho View PostI haven't hit the weights in a few weeks, and I immediately noticed that I'm losing weight.If it can be done wrong, I will...somehow I always finish tearing things up before I can fix'em ...
updates...down to a tight 193 lbs. Still working out 3 or 4 times a week...most importantly have (hopefully) laid long-term substance abuse issues to rest with almost 60 days without the most personally damaging drugs known going into my system. Reality doesn't suck like it used to...sleep is no longer a mystery. Anyone brave enough to share their story ?If it can be done wrong, I will...somehow I always finish tearing things up before I can fix'em ...
WtF,
What the Hell is wrong with you, you want all that kitty-kitty and your running around like, it damn near kills you. Eat a little, run a mile, repeat this 3-5x daily and you will be much happier...it will keep you young and vicarious too! you won't need to leave a signature like that anymore. With that kind of regimented workout you will be the new God Farcicus. Fergit, Got Wood?
It be like, I gotta conda made a stona! King Farcicus The Great!!
Best of luck you arrogant little Bostert!
Gotta get some pussy no matter what.....
even if it from dirty slut.....
true love is what i want the most!!!
iiiiiIIIII just jerked off in your french toast!
Originally posted by kozzman555 View Posti usually run 7.2miles of mountainous pennsylvania roads home from work everyday. 9.0-9.5 (not sure exactly) miles if i have to take the long way and stop at the bank. try doing that without stopping. it damn near kills me. when you run, push yourself a little harder everyday. if you can run 1.6miles without stopping, try 1.8 miles the next day. you have to push yourself just the extra little bit to get better at it. when i first started running, i could only run like 4miles and had to walk 3miles (it was run a bit, walk a bit, run a little, walk a little), then i gradually increased it to where i could do the whole thing. it went from running 4miles to running 5, then 6, then 7. YOU CAN DO EET!Last edited by riverrunnernky; 04-07-2007, 04:35 PM.David
sigpic Ky
Nice to hear you are over the substance abuse Meltdownsky. Taken from the area you live in, I suspect meth or crank. Over here in CA, everything is everywhere, so my major problem was the ganja. I know it sounds lame, but that stuff really effects my productivity, grades, motivation, and social life.
And nothing will ever be sore enough!!!
Never Enough!!
