yes its mine.......
yes its mine.......
Tags: None
it ran....... i assembled the turbo setup & took it for one spin.
i had serious blowby issues previous due to rod stretch & piston/head contact.
& if it breaks....... i upgrade it...... so now its watercooled too
i might have potentially burned out the oil seals in the turbo (pray i didn't) i'll find out when i reassemble the motor again.
worst case scenario. i run it without until i can get a replacement
i also relocated the turbo's oil drain into the crank case in a lower pressure zone & added case vents (not previously there)
the original drain was setup in place of the oil dipstick. which i found with blown rings & serious blow by would push oil back up the drain blowing out the seals as the RPM's increased.
there were smoke trails riding back on the only run it saw.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
call me a noob.... but i have to figure out how to edit & shrink down my videos so i can upload them.... :/---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
always loved this idea, can't wait for it to be finished tho! The hatch should take priority anyways tho-Jack
