holy mother of god, those are some nice rods
Rods rods rods
Lex you will like these rods. When I got mine I checked over everything as well and everything checked out fine. The rods are very well machined and seem to ready to take some abuse. I had no problems installing them. Just make sure you stretch the rod bolts when installing don't torque them. GL man!hello 4g63 nice to meet you
stretch? not TQ? you lost me on that one there^^^---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Poststretch? not TQ? you lost me on that one there^^^
http://www.arp-bolts.com/Tech/TechInstall.html**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
Originally posted by Tazman2 View Post
Fastener Retention Overview
There are three methods that can be employed to determine how much tension is exerted on a fastener; using a torque wrench, measuring the amount of stretch, and turning the fastener a pre-determined amount (torque angle). Of these methods, use of a stretch gauge is the most accurate.
It is important to note that in order for a fastener to function properly it must be “stretched” a specific amount. The material’s ability to “rebound” like a spring is what provides the clamping force. You should know that different materials react differently to these conditions, and ARP engineers have designed each fastener to operate within specific ranges.
On the other hand, if a fastener is over torqued and becomes stretched too much – you have exceeded the yield strength and it’s ruined. If the fastener is longer than manufactured – even if it is only .001,˝ it is in a partially failed condition. Therefore, ARP has engineered its fasteners with the ductility to stretch a given amount and rebound for proper clamping.
Heat, primarily in aluminum, is another problem area. Because the thermal expansion rate of aluminum is far greater than that of steel it is possible to stretch a fastener beyond yield as the aluminum expands under heat. An effective way of counteracting material expansion is through producing a more flexible bolt.1993 Protege LX-Midnight's shadow SOLD
I know this is reviving a thread, but it does not hurt to ask LEX how have the rods worked out after two years on the motor?
Any glitches? complaints? things to look for?
I read about all the machining you went thru and some reviews a little after install, the question is based now that more than a year has passed by and I am curious how have they performed at the long run.
Thanks in advance
