Let me start with, I'm still gathering the last few parts I need to do this.
Edited Inventory as of 4/13/13
Ksport RR Coilovers (trading BG lower mounts for Probe pieces)
All four Knuckles from my 89 Probe GT
Two 1st gen MX6 N/A front wheel hubs
20 ARP Extended Wheel Studs (need to sell the ones I tested, and purchase part number 100-7708)
New Front and Rear Wheel bearings (89PGT)
New front and Rear Rotors (89PGT)
New Front and Rear Calipers with brackets (89PGT)
New Front and Rear Pads (89PGT)
****sport Braided Stainless Brake Lines (all 4)
New 86-88 RX7 Lower Balljoints
New MX3 Outer Tie rod ends
89 Probe GT Parking Brake cables
MX3 TTL's
MX3 Rear Subframe and tiebar (temporary, will be replaced with Pierce tiebar shortly)
MX3 Rear Swaybar
Zx2 trailing arms (and new ES poly bushings)
six 16" 1996 Mustang/Cobra wheels with 4 Falken 205/45R16's (2 are bridgestone tires same size)
four 15" 1996 Mazda 626 wheels with 195/55R15 Hankook Snow tires
Needed parts/work as follows:
Ferdi's Tie rod Flip kit bushings
ARP PN 100-7708 x4 packages
Some prep work
Some paint work
Some powdercoating
Some freetime
Later when swapping in the KL engine, I will be adding:
MX3 LCA's fitted with Ryan's sphericals
MX3 GS De-Powered steering rack
MX3 Steering column
New MX3 inner tie rod ends
Some bonkers JDM mazda steering wheel (probably FD or NB or something)
Pierce Rear TTL's and some sort of strut mounted Rear sway bar
And if there is enough clearance to permit their purchase, I have picked a set of 16x8 +25 wheels that I like for my non-commute functions. To be fitted with some Sticky street rubber I.E. Dunlop ZII's or the like.
The plan is to start prepping my spare complete MX3 rear subframe and TTL's this week, basically build a complete 5 Lug bolt on rear subframe off the car, and once I get rear wheel bearings and studs for the new rotors; finish it and set it aside.
Then I will setup the front on the car when I finish gathering those parts, and the same day I will swap in the complete rear setup as well. It might be a week, and it could be a month before I finish, but I'm getting close.
MX3 TTL's
MX3 Rear Swaybar
Some prep work
Some paint work
Some powdercoating
Some freetime
MX3 Steering column
