110 is leaded gas. It will destroy your cat if running one. 100 is all you need to run and is un-leaded. Gas wont make a car blow up either if anything its going to help it from not blowing up. It helps prevent deto. Id say either too much boost, bad tune, lost oil psi exc deff engine parts related not gas
Blew my motor
Well there is no cat on that car first off, second the car was tuned, third the motor had 180k. When we pulled the head off cylinder #'s 2-4 were burning perfectly. Cyl #1 had a lot of carbon build up and the cyl wall was grooved pretty badly. I think that cyl #1 was damaged probably with a loss of compression and the combo of the gas, irridium plugs and msd ignition, and the boost, didn't help.
He was runnin 9.5's at the track before we went home. I say its gas related and mabe timing related.Last edited by TurboProto; 05-31-2006, 08:45 AM.
Originally posted by Proto420Well there is no cat on that car first off, second the car was tuned, third the motor had 180k. When we pulled the head off cylinder #'s 2-4 were burning perfectly. Cyl #1 had a lot of carbon build up and the cyl wall was grooved pretty badly. I think that cyl #1 was damaged probably with a loss of compression and the combo of the gas, irridium plugs and msd ignition, and the boost, didn't help.
He was runnin 9.5's at the track before we went home. I say its gas related and mabe timing related.hello 4g63 nice to meet you
yea you could change out the stock connecting rod's and pistons, wich would handle 110 racing fuel. 110 burns real hot and produces a faster bigger explosion. wich the stock connecting rods and pistons cant handle. see if you want to run boost and 110 fuel it would be a good investment to replace the stock connecting rod's and pistons that way you wont blow the motor as easly.stock blaze red 1992 Mazda Protege DX 5 Speed
the real question is did you make any good passes?
also 110 is a cooler burning fuel. the higher the octane the slower cooler burning it is. it helps retard your burn cycle with out touching your ignition. do the math why do boosted car have higher timing marks and run higher octane fuel. when stock cars run lower octane and lower timing. compression has zero to do with this issue.
NEUMANLast edited by neuspeedescort; 05-31-2006, 06:07 PM.
Exactly.
The higher the octane of the fuel, the slower, more complete combustion is. This means that detonation is less likely. Lower octane fuel ignites much easier, and carbon build up, such as in the motor that were duscussing, will get red hot, and will cause detonation before the spark can ignite the mixture.
My bet is that it had something to do with the carbon build up in cyl. #1, and the boost was the stick that broke the camel's back.
You can tell from the picts that #1 is more carboned than the rest. Luckly the cyl looks like it has no visable damage, but only a machinest can tell the truth.
Originally posted by elscotto80 View PostHoles in the block, always a good thing.
It's fixable!!!1998 Subaru Forester S/Turbo | Shaggin' Wagon
1990 Mazda Miata MX5 | WTF I can drag asphalt with my hand
2003 MuZ Baghira 660 SM | Single Slammer
2008 KTM 250sx 2T Supermoto | Kart Track Killer
Shift_Buy Broken & Build...
Holy old post..
He definately detonated that engine..
I dont know what he is running for engine management, but unless you have some kind of standalone there is absloutely no point in running crazy high octane fuel.
10-12 psi? Holy lord! What turbo did he have on it? Unless its off a mac truck its definately a tuning problem. 110 octane would be fine if he was tuned for it.. but you cant just crank the boost up and think that higher octane will be a band aid for a bad tune.
Anyone know what his setup was at the time?93 MX-3
BP, Wiseco Pistons, Pauter Rods, Haltech E6X, Turbonetics T3/T4 Ball Bearing, 3 inch turbo back exhaust, Bully Six puck clutch
"Jesus, its raining out! I cant get traction in this!!!"
I guess you didnt read the previous posts. The motor was a stock bp05 with 180K+ miles with a complete bp26 turbo setup, fmic, Denso Irridium plugs, and stock 94 ECU. The car ran fine at the track until we upped the boost on the fwy so he could keep up with me and then boom! I was runnin the exact same gas as he was, and my car ran crappy around town but it loved wide open thottle. His best run that night was a 9.5 @ 77 mph and mine was a 9.30 @ 80 mph. In the 1/8 mi.
Originally posted by XxToKeSxX View Post#1 cylinder?
Why is that that its always the #1 that shoots when an engine goes... maybe I've just been seeing a lot of that lately... on any engine.
Peace,2002 mazda protege es with forged pauter cennecting rods, forged cp 8.5:1 pistons, ARP head studs, streetunit polyurothane engine mounts, spec stage 3+ clutch, spec 6.8 lb. aluminium flywheel, mazdaspeed tig welded limited slip diff.
1992 mazda mx3 ( Bugs's old ride )
