ouch that sucks it looks like my old motor after running 20psi
Pieces of me
What box is that exactly?
Nice Singles Spinner Diff hehe1987 Ford Laser TX3 4WD with BPT FWD LSD
GT2876R, Turbosmart Ultragate, Weisco Forged Pistons, GTR Conrods, Race Flowed Head, HPC Tube Manifold, GTR Plenum, 550cc RX7 Injectors, Custom Fuel Rail, Infini LSD Diff, Straight Cut PAR 3rd Gear, FMIC, 4" Intake etc.
320HP at 24psi Pump Fuel & 12.5 @ 122mph Street Tyres
g series, I've since upgraded tot he MSP lsd (love it too)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Yeah, LSD is awesome for the drags without blowing.
Straight 3rd should be next on yoru list1987 Ford Laser TX3 4WD with BPT FWD LSD
3rd along with the longer 5th i have & full cryotreatment is next.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
how much was ur msp lsd?My Car Domain
My VB Garage
1994 Protege LX
Cold Air Intake
Cat Back Exhaust
5 Speed Tranny Conversion.....Coming This Summer
in total ~$500 including bearings & press work, my own labor.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
LSD is the best mod you can do on FWD. Stops the Diff Pin and Spiders blowing to bits when spinning the wheels.
Get a Straight-cut 4th as well. Mate just blew 4th on the dyno for the first time.1987 Ford Laser TX3 4WD with BPT FWD LSD
4th gear?? @ what power?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by QuicKSilveR View PostLSD is the best mod you can do on FWD. Stops the Diff Pin and Spiders blowing to bits when spinning the wheels.
PS: I still don't understand how LSD helps solves the issue but okay...**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
because when youve got a one-tire-fire situation, theres a huge amount of strain on the diff spider gears.
-jonEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postbecause when youve got a one-tire-fire situation, theres a huge amount of strain on the diff spider gears.
-jon**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
PS: I still don't understand how LSD helps solves the issue but okay...because when youve got a one-tire-fire situation, theres a huge amount of strain on the diff spider gears.
after i blew my tranny i welded that pinion shaft. That diff is still in use to this day in my buddies tranny. IF you plan on going over 160WHP weld the pinion shaft or you'll fry the diff, garunteed---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
