Sounds good guys, thanks for you help! Much appreciated... I'm feeling pretty sh!tty cause of this, being so close to finishing the turbo part. You should of seen the sauce (tranny fluid) that came out of the tranny... it was a metalic goo... so it wasn't even red fluid type looking... more of a metalic grey as if the gears were grinding a lot.
I'll let you all know what I find when I drop it out and tear it apart.
I don't see why it would be 3rd or 4th gear even... it was always second gear that gave me problems, when I'd fast shift from first to second it was sometimes not sync and I'd get that grinding feel. Then let go of the clutch and throw it into second.
Member of MX-3.com
I know I haven't even got the turbo on the motor and she's already ripped apart the tranny.
I looked in the grey metallic goo, and filtered out the other pieces I saw... I didn't get to take any pictures, but I found the other half of the tooth, and it had 4 grooves in total on it. It was pretty wide and I'm sure it's the LSD ring gear.
Is it possible to just buy the ring gear assuming nothing else in the motor is ripped apart?
Also does anyone have any links to information about using the MR2 tranny? I'm gonna start researching now, and post anything I find.
Member of MX-3.com
Hmm, I don't remember any ring gear having 4 grooves.
Jon the is the guy to talk to regarding the MR2 tranny swap as he is researching it right now.
You can't buy the ring gear seperate. And, you don't really want to use one from a Mazda box because they are thinner than the one that comes on the MSP diff. You would need to get one from a Kia. I don't remember, but I might have one from a Kia.
Thanks... yeah I'm a little upset... so damn close, yet so damn far.
Well, I'd like to know what gen MR2 this tranny has to be from... there's one for sale from a 1986.
Member of MX-3.com
I have a Kia diff Jon if you want it. Open, but complete with the ring gear.
Thanks, I still have the original open diff from that tranny... right now I'm researching MR2 tranny.
Member of MX-3.com
you can use another stock ring gear but you'll need the ARP quaife bolts to bolt it to the LSD. i would reccomend using the secondary shaft and ring gear from the same tranny if possible. probe trannies (v6 and 4) use the wider ring gear and 4.10 if you dont want to buy a kia trans.
if you want some info on the toyota thing let me know. get in touch with me on AIM or something and i can explain what i know so far.
i'm going to try and pull it off, i'll be able to do a full write up on it once i'm done.
Yeah I was looking up on www.mazform.com and saw you talking to the guy about doing a FWD tranny instead of the AWD one. I saw that guy had a conversion plate made, and a short write up with pictures on how to. I'll will contact you after I've tried to inform myself a little more, so I am not asking too many stupid questions.
Things I know so far:
Seems like you have make your own engine mounts... nothing about cutting the frame rail, thank gawd... you have to cut the bellhousing to get the starter to fit... for the AWD tranny you have to modify the oil pan, unsure for the FWD... Either use a MR2 tranny or a Celica FWD tranny, not sure what model or make but some MR2's came with LSD... apparently you can use the Toyota axles but they're a tad bit too long but the same spine count as the hubs... it's all cable shift with two cables?...
Member of MX-3.com
