any details yet about whats going on inside your tranny Shades?
i'm not going to do a full write up until its actually done, since this is kind of all speculation at this point. heres what i know so far:
Parts (that i have bought/am buying):
-adapter kit from NZ (plate, front/rear mounts, crossmember, bracket for upper mount, clutch slave and hose, other small odds and ends)
-custom clutch disc (toyota center hub, mazda-size friction material)
-1999 camry v6 tranny, shifter, cables (this is "the same" as an open diff mr2 turbo tranny, but with different gear ratios and the shift linkage is setup for FWD)
-1994 MR2 viscous lsd, drivers side axle stub, passenger side intermediate shaft
-1991 (ST185) Celica alltrac front axles
Custom stuff i need to do/make:
-bracket to bolt MR2 intermediate shaft to BP block
-mods to tranny outlined on Mazform
-mount shifter assembly, route cables through firewall. i may need to get a shifter assembly from a different car, the camry one is awfully tall.
-figure out what i want to do for the speedo
-lots of other stuff that i'm sure i will discover along the way
