You posted a picture of the white car's diffuser a page or two back, just caught myself up on this whole thread, that's a sick build! Can't wait to see it done!
Roadrace EGT Touring Car
Not a bunch of work done, but pulled the pedal box out and setup the MC/resivoirs---should start plumbing fuel/brakes this month.
Got the brake pads today---Hawk HT-10 in the front and blues out back-they just look meaty!
A little progress on the brake system---after making 2 trips to earls/autoparts stores getting hardlines/fittings/residual valves etc. we should have everything we need. Started at the master cylinders...
You know---the next series up (9000 series) has about an 1" of adjustment up/down---these don't (except for pedal covers), but they're designed to be in the sweet spot and meticulously machined for precision control/ergonomic/just plain whammy...we've installed sliders on them before to accomodate oddly proportioned drivers (trees/trolls). Got some more done today---Go Casey Go!!! (Dimwatt)
axel boot squished why??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
lookin great!!!-Jack
Originally posted by FE3-323 View Postaxel boot squished why??sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
Yeah Jon-didn't see any issues with it---finished up the brakes to the calipers---had earls make the rear flexible lines, pretty reasonable---$40 bucks...could even bleed the brakes now if I wanted to (this is huge considering the car hadn't been touched in nearly a year!)...moving on to the clutch, then next week steering, then plumb fuel...it's possible it might even be finished for the first race next year...
Last edited by JPmotorsports; 11-05-2010, 04:24 PM.sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
^ yep
Thanks! Got most of the parts together for the fuel system---since this fuel cell doesn't have the collector box inside I'm hoping the big HP1 filter will help---I plan on running the small inline russel filter out of the tank to the pump and then the big filter between the pump and fuel rail. Anyone run the HP1 filters before on fuel injected stuff??? We've used it with carbs on offroad racetrucks without any issues---just don't want any pressure issues at the rail...should have a clutch by the end of the day.
