Roadrace EGT Touring Car
    Oh snap! What happened to your head? lol
      That's Casey Dimmitt "Dimmwatt" as he's known on the FEOA.net boards---he walked into an exhaust hanger on a Dodge Charger about an hour ago. He's helping with the wiring on the car.
        Originally posted by JPmotorsports View Post
        I am! Longer---probably around 75mm and then rounded off for quick tire change/lug engagement.
        cool i hate my studs because you have to take your time putting every lug on because they are flat at the end
          I noticed also that the shifter hole has been relocated further back for a taller driver? Are you going to just extend the stock linkage or are you making something more reliable than the stock shifter with the rubber mount that falls out over time.
          And also I have purchased a few coilvers from ksport for 240's and they work alot better than the first generation of ksport shocks. And im curious if what you have is a custom shock/spring rates or is it something I can order through my company? Cause I dont want the old valving setup on my car cause they dont last like the newer ones do.
          1990 Protege 4wd: BP05 forged internals, Mild ported head, GTR intake manifold, Gates racing timing belt, GTX transmission, Stage 3 clutch, 60trim T-3 turbo, Custom down pipe,3" Stainles exhaust, , Walbro fuel pump, RB-Performance fmic kit, HKS bov, Aurfa coilovers, F&R drilled slotted rotors, 16" BBS wrapped with Advan Novea tires, EDM glass headlights with HID's, Familia front and rear bumpers.
          Boosted 1990 4WD
          http://www.wihandyman.com/forum/showthread.php?t=32462
            The whole driver has been moved back 10" and inboard 2" for better weight distribution. We'll extend the shift rod the ten and run with it until we have issues/failures. Ksport offers a couple different models of shocks with different options/valving. We found a spring rate that works good on the racecar/ track car. We sell them with the normal valving/cartridge and then we have our own setup that we've developed as well for sale. I'm direct with them, pm me if you'd like a set and I'll work with your biz/resale. I have a set of the custom RR dampners in stock...
              some studs like these..... ARP ones I just put on the rear axles of my Corolla.
              Hmm, I should check to see if the knurl diameter is right for the ford/mazda studs. kind of expensive, though, about 51 bucks for a set of 5 was the least expensive I found online. Worth every penny, though, to keep the wheels on the car and not stripping the ~4-5 thread engagement that they had before.
              I'm looking forward to seeing this build finished, and see how blazingly fast you'll be heading around the track with it!
              --sarge
                More like these!
                  sweetness! Where'd you get 'em? I'm betting they were cheaper than the ARP ones by a few bucks...
                  --sarge
                    Their from a company called bimecc and they were $90 for 25 and then about $80 to machine the bull nose---not exactly "cheap" either---but very worth it. They also screw in as well so they are easily changed in the event of an "accident".
                      Definitely neat-o. the screw-in function sounds sweet, too! what sort of threadlocker do you use to make sure they don't accidentally work their way loose?
                      --sarge
                        On the Porsche stuff we tack the back of the stud to the hub. I suspect you could use a mild threadlocking compound though (blue), there's not a lot of stress/load in that "direction" on it. The one time we had a damaged stud we were able to chisel off the tack and change the stud in the paddock.
                          Alright sounds good. Also remeber I have 4wd and its alot heavier than a stock EGT or Proto. Im going to need some semi stiff springs but not too long cause I want to keep the car nice and low but with a semi smooth ride.
                          Boosted 1990 4WD
                            damn god damn ksport !! how much that run you im dying for a set of those .
                            ~~~~~~~~> Thanks again to member gooseinyou for the familia garnish <~~~~~~~~
                              Are you allowed to run a fmic on that car for the type of class your running? If so i would like to donate one of my fmic kits to the race car. If you don't already have something planned out.
                              Boosted 1990 4WD
                                I wants your front brakes! What's the background on those?
