you have a ford harness but a mazda cluster, that sensor is for just the cluster anyways, the ecu gets its temp info from a different sensor
91prodx to bp swap - deathtrigga
What do you have the timing set at? almost sounds like its a little on the retarded side91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Sub'n to see if what I said on aim worked lol. If so I expect a vid of you doing this1993 Protege LX-Midnight's shadow SOLD
