What did u do with the blue vc
Ace's never ending log- 94 Pro DX
curious to see what you have going for the coolant lines---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Well I though I saw a t3 adapter plate then I saw your post in the BG section. Nice upgrade.Last edited by bomdoutscort; 08-26-2012, 03:57 PM.Cincinnati, ohio Bengals for life
"Who Dey"
definitely interested in seeing these push-loc fittings in use! How much is it costing you to do the two turbo lines? I'd like to do those, as well as the TB and IAC lines.-Jack
push loc fittings are cake, I use them on customers cars at work sometimes. I'm not using the push loc hose fittings on my car though, just the hose because its extremely durable and looks good. The hose is fairly pricey though. I got a 45* 3/8npt 1/2 hose barb for the oil pan though. Which wasn't cheap either. lol
actually ace....... you'll make more power with the 2nd gen intake manifold then the GTR mani....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
larger dynamic chamber on the 2nd gen is worth a dyno'd 1 WHP increase with no other changes. (**you can cut the 2nd gen design just like the 1st**)
the flow of the 2nd gen design is improved over the 1st gen unit- it has virtually equal volume to each runner due to the plenum taper inside.
benefits of a GTR manifold are strictly equal flow. compared to the GTX manifold it provides more tq because it has a balanced plenum (unfortunately a smaller area tho)
i've been a fan of the NA manifolds because of the "dual plane" runner system(VICS) the engine really does need/utilize this.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
