Love it, been thinking off painting my black GTR white but could be swayed too this colour
323 GT-R Built
Little update after one week of work on the car:
Took the engine/tranny out
Replaced the rear main seal, crank seal and redid the oil pan seal...it was leaking at both ends.
Replaced distributor seal, was leaking. Took the time to clean everything and paint the oil pan.
Replaced one ball joint
Painted the intake manifold and got a new Turbo Intercooled sticker for it.
Painted all caliper
Installed stainless steel brake lines (Corksport)
Instaledl a boost controller (Perrin)
Installed a K&N air Filter
Installed new fog lights
Repainted wipers arms + new wipers
Still need to work something for a boost gauge
Powder coat front strut bar, same color as valve cover...didn't get to it yet
Installed new clutch (Bully Clutch Stage 3)
Installed new vacuum hoses (Hose Techniques)
Repainted hatch moldings (paint pealed off)
Sent all 4 rims to get refinished, will get them back sometime this week
Waiting for the rims to come back, and I will take some final pictures of all the work I did...then you can comment
Pictures to come...Last edited by 323 GT-R; 07-05-2009, 11:17 PM.
Now thats the way a GTR should look , unlike this thread I just got done reading........can you say rice a roni. You sir are a true Mazda fan.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Now the real work begins
The plan was to replace the clutch on my car...but here's what I ended up doing...
1- Replace Clutch
2- Replace Oil Pan Gasket + Repaint Oil Pan
3- Replace Rear Main Seal
4- Replace Crank Seal
5- Replace Distributor Seal
6- Repaint Intake Manifold
7- New Intake Manifold Gasket
8- New "Turbo Intercooled" Sticker
9- Replaced all Vaccum Hoses
10- Replace Clutch Line for a Braided Stainless Line
11- Replaced Stock Air Filter for a K&N Intake Kit
12- Replaced Fog Lights
So here is where it all starts!
Took the hood off to make all this easier
After a few hours of work here it is...
You can see behind the engine all the parts removed...
Took the intake manifold off
Front end was removed to prevent any bad accident to happen to the lights/bumper
It's at this point that I've decided to replace all the bottom end oil seals...
After a few hours a cleaning and removing all the oil seals...I started to put it back together...
Ready to go back on the engine...All nice and clean!
Timing Belt back on...
All Heat Shileds repainted
Now it's time to put the clutch on this good looking engine!
I've put the tranny back on and now its time to put it back in the hole...
Lost track of time...didn't take much pictures of the all the work to put it back together...but here's a final picture of all my hard work!
And now with eveything back on..Bumper, Lights, Hood and even new Fog Lights!
! well done sir! thats a good amount of work to accomplish---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Beautiful Work! I'm wondering if your radiator would fit in an EGT though..? What brand spark plug wires are those? I'm running taylor thundervolt. How does the 6 puck clutch feel? Any trouble off the line hooking up without chattering? Any violent engagment'? Don't forget about your rear end fluid!
Originally posted by cis2711 View PostBeautiful Work! I'm wondering if your radiator would fit in an EGT though..? What brand spark plug wires are those? I'm running taylor thundervolt. How does the 6 puck clutch feel? Any trouble off the line hooking up without chattering? Any violent engagment'? Don't forget about your rear end fluid!
The spark plug wire are Magnacor 8.5mm
The clutch feels very nice, at the take off (1st gear) its smooth...but when you floor it, it holds up all the power and doesn't slip at all...I like it a lot! Best upgrade so far... I didn't try any launch or anything too aggressive I'm still doing the brake in...
All Fluid were replaced...I'm using Red Line Products...
Very nice work1993 Protege LX-Midnight's shadow SOLD
Hey I'm going to Cornwall this Sathurday, if you're interested, you could going there. Even I could catch you when I got through Montreal?-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
-2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
-2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
