Hey man, if that mill works with the adapter plates you and I bought, it ain't OT a'tall!
Toyota E153 transmission swap
it wont, the FE3 uses an F series bellhousing pattern. for example it will bolt up to the 626 FS transmission
i'm sure Tim could design it but you wuold need to get an FE3 down to his CMM shop...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
gah. Not enough extra cc's to bother with for that, if i run a different engine it's gonna be that 2.3 (2.5 if I could find one) duratec.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
i still think an AWD v6 protege rallycar would be beyond cool
obviously that would be pretty tough though.. the block is probably way too wide to clear that toyota rear transfer. heck the BP doesnt even clear without grinding stuff down.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by chrmar View PostFE3 was only ever offered in NA in the Kia Sportage. This engine and head isn't as good as original Mazda offerings due to lower quality standards in the manufacturing process. Also, if you source an FE3 from a Sportage you still need to get an intake and exhaust from a FWD application which was in MX-6 and 626 models in Europe, Japan and Australia/NZ. They have a similar relationship to B-series engines in that FE3 is to BP what F2 is to B8. They can be shoehorned into BG chassis cars and in turbo form throw out a helluva lot of power.
Yup. F2t crank+some sort of shevy rods and pistons and you'll have a motor capable of handling 600+ hp. Hell the original fe3 can handle 400hp as is. This is just info I've had been told.
Too keep it on topic.....FE3-t+yota tranni at 600whp would be nuts.1993 Protege LX-Midnight's shadow SOLD
heck if my gtr motor ever lets go i'm just going to swap in a 3SGTE...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postheck if my gtr motor ever lets go i'm just going to swap in a 3SGTE...
Originally posted by therieldeal View Postheck if my gtr motor ever lets go i'm just going to swap in a 3SGTE...92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by redheddude222 View PostI thought that was the N/A Supra motor, not the 4 cylinder.
I have heard of it many times for the 3SGTE for stock but mostly modified engines and the only solution is to have the block machined to accept copper O-rings, or swap it out for the Camry 5SFE 2.2L which is supposedly a very strong engine.92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostI have heard of it many times for the 3SGTE for stock but mostly modified engines and the only solution is to have the block machined to accept copper O-rings, or swap it out for the Camry 5SFE 2.2L which is supposedly a very strong engine.
________
Dodge Demon ConceptLast edited by Blazin674; 05-02-2011, 08:28 AM.1995 escort wagon gtr/holset
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
FE3 would be sick.
The rods are almost twice as thick as the GTR rods, and the pistons are strong as hell too. There are many different compression ratios available, 10:1 being the highest (and apparently most worthwhile), along with four different camshafts to choose from (FE5A has the longest duration), and the availability of a .2L stroker kit from a F2T engine (first gen ford probe GT, same probe the BF GTX guys use to make a VJ14/VJ11 hybrid turbo). Also the VRIS function in the intake manifold alters the length of the runners at 3800rpm to give it some extra torque at lower RPMs. The blocks are braced, have strong internals, are nearly the same physical size as the BP engines (hell they can be run off of a BP ECU), have plenty of meat between each cylinder (at least for 0.1L total overbore, I want to shoot for 0.2L if feasible), DOHC 4 valves per cylinder (though you'll want to replace the exhaust valves with a set of intake valves, the exhaust valves are able to rotate in place when they expand due to heat soak, not good for high performance engines) (also might want to replace the larger valve springs with some out of a VW VR6).
These engines are killer, don't be fooled by a measly 0.2L increase, you can easily change that to 0.4L and turbo it with factory internals AND still have it reliable.
jeez guys if you want to talk about the fe3 lets start a new thread lol
in other news, i am hoping to have the plate in my hands by the end of next week. i have the week of labor day scheduled off from work (has been for months) so the timing seems to have worked out just perfectly!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
