Hey... wheres the video?? you still eating, lolz
Mazdasly75's GT-R
Lol! Yeah taking a breakfast now. By the time I was ready to drive it yesterday, darkness took place and I had a 80km trip to get back home...so I left without the camera but I'm getting on it right after. Pics are uploaded in my photobucket. Got to put the mirror in this thread so you can see the rest of the work...-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
-2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
-2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
Here's the rest of the build:
the turbo piping
After that I had to fit an oil cooler. I first wanted to put it in between the FMIC and the rad, but I could just get a hand, no more room allowed because of the new size of the radiator. So I had no choice to use a fog area to mount it. I know some of you will disagree with this idea, but thrust me, I tried to fit it anywhere else in the engine bay and nothing could achieve a better job by letting fresh air going through it than the fog hole.
And after that, I installed a universal aluminium mesh grill, that I painted in black.
A year without running = dust
There's an oil filter relocation sitting just under the MSD box.
From the underneath of the car
Bleeding the cooling system
And it's ready to go...a little video, car still under break in period, boost only 7psi, boost cut set @ 10psi, and shifting the redline for now @ 6500rpm, 3rd-4th gear pull...but the engine wants more!! You'll notice that I hit the boost cut early after shifting the 4th. I only hold throttle for 30% according to MS !"/$%?&
Some of you probably noticed that there's no air filter yet, but it's on its way, the screen is temporary.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Originally posted by b19gtr View PostSly, the car sounds great. Did fitting the cams affect your trigger angle.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Originally posted by b19gtr View PostWould it be possible to post your timing map .
wow! so glad you got the car running before the winter hits! awesome!! I hear some pulsating noises before you hit redline as well...any idea what that is? wastegate opening up?-Jack
Before you copy/paste this map into your .msq file, I'd like you to be really careful. This map has been developed for this engine and the main things behind the aggressive timing is the modified combustion chamber of the head and I'm running on 94. It's made for 25psi, I did tuned it using a progressive AFR from 12:5 @ 5psi scaled down to 11:1 once you reach 25psi. BP engines loves fuel under boost, I remember when stock, the GT-R factory fuel map was 10:1 @ 20 psi...I did tuned this timing map using exhaust gas temperature reading, audible knock tool (knock sensor unit installed on the block with a transmitter and headphone), and G-Tech pro.
Thanks
Originally posted by Mazda_Powered View Postwow! so glad you got the car running before the winter hits! awesome!! I hear some pulsating noises before you hit redline as well...any idea what that is? wastegate opening up?
Thank you very much for your support Jack, without your appreciation, it would have take forever to finish this project. I spent almost 300 hours on it.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Originally posted by b19gtr View PostI see what you mean by aggressive. In terms of EGT, what sort of temperatures are safe in the crusing part of the map and also on boost.
ThanksLast edited by mazdasly75; 10-12-2011, 09:32 PM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
