JE's pistons are made light, the top of the piston is so thin compare to supertech. By saying it's stronger, I'm mostly thinking of being melt instead of cylinder pressure. With JE, once you touch 1650F, the piston's going down the pan in a lightning. I've seen Wiseco's holding 1700F for 30sec without getting damaged. The Supertech's coating will help resisting to excessive heat.
Both JE's/Supertech's pins are chromoly, but again, Supertech's pin is thicker.
In my opinion, JE's are the best for N/A cause they're going to the limits by shaving down it's parts.
