Thanks! I got the rods through ebay
Mazdasly75's GT-R
-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
-2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
-2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
scats rodsLast edited by mazdasly75; 05-19-2010, 12:31 PM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
here it is, just got back my crankshaft for a full knife edge and balancing job. The result's awesome. Here few number from what I got. I brought 3 cranks to the shop and we compared those. We deceided to knife edge a stock BP one wich was in a better shape than the 2 others.
-the first one is my own GTR crank that weigh 36lb. yeah, the gt-r crank weigh 1.5lb more than a stock BP one
-second is a stock BP that weigh 34.5lb
-the 3rd is the knife edged that weigh 31lb
here's the pictures of a stock BP and a knife edged BP crank
stock BP
Knife edged
Look where they removed material to balance it. The polishing finish is just awesome!! I like it!!
Last edited by mazdasly75; 02-05-2013, 08:22 AM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
let's do some maths now. There's a lot of mass removed off the internal.
Stock GTR:
-piston, 495g x 4, 1980g
-rods, 685g x4, 2740g
-flywheel, 21lb/9525g
-crankshaft, 36lb/16329g
Total: 30.574kg/67.4lb
After the diet:
-JE pistons, 299g (matched) x 4, 1196g (saved 784g)
-scats rods, 524g (matched) x 4, 2096g (saved 644g)
-fidanza flywheel, 9lb/4082g (re-balanced with pressure plate) (saved 5443g)
-knife edged crank, 31lb/14061g, (saved 2268g)
Total: 21.435kg/47.25lb
Total mass removed: 9.139kg/20.15lb
Awesome!!! I'm now waiting for new ACL bearing, they're B/O...after I'm assembling back the beast.Last edited by mazdasly75; 05-19-2010, 01:06 PM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
From Thursday to Sunday, I'm assembling back the GT-R, so expect lots of pictures, again , of the work. The list of things to do now:
-Put back the engine in one piece.
-install new frount mount oil cooler, FMOC lol.
-New eibach drop suspension.
-Change both rear wheel bearings.
-Install new HKS EVC VI boost controller
-Install new HKS turbo timer.
-Install new discs and pads brake to the 4 corners
-Few mods over my stainless 3" hexaust line, deleting the high flow cat + welding V-band clamps instead of flanges.
-...and the things I'm missing right now.
So stay tune!-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
excellent excellent work man. very impressed with the care that has been put in your engine. looking forward to some action videos. many thumbs up man.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
nice man! hope all goes well!-Jack
They were the same diameter as a stock BP except for the exhaust side, the valve is sodium type so it dissipate the heat through the valve steam instead of the seats.
They're for sale if you're interested, it's a bolt on. http://www.wihandyman.com/forum/showthread.php?t=47026-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Hey just a quick note to let you know that I got now a 8000rpm monster!!!
the car is running stock waste gate (14.7 psi) and pulls as much as 20 last year. I got lots of pics and a video of a 0-190km/h acceleration. I now reach 190km/h in 4th gear while I was hitting cutoff at 170km/h with the same transmission. I'll give a shot with G-tech and I'll post all the stuffs in the next 3-4 days!-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
awesome!! glad she's running strong!!-Jack
