Got the lower front mount made. Right now, we have the engine no farther forward than 1/2" from stock, and about 3/4" high. The trans just clears the steering rack. Unlike everyone else, this lower xmember needs very little modding. Fair's fair. We had to take sooo much more off the xfer case to get it to clear the block then everyone else, it's about time we caught a break. We took a small section out and replaced it with a piece o' square tube, nothing interferes and the skid plate will install the same as before. Once the other mounts are made, next up is borrow a set of st185 shafts and see do they work any better. Cuz you can see how bad the articulation is in that last pic. We either need to drop the drivetrain so far down that the skidplate needs reworking, thus lowering ground clearance on a rallycar (real bad idea, that), or we figure out how to get rid of some suspenion travel. Limit straps like the desert trucks give none of us the warm-n-fuzzies. No room in the fenderwell like them other fellers. These shocks only travel down about an inch farther than stock, but the shafts come out about an in higher than stock, so, here's hoping the shorter shafts make everything all better somehow.
Then it's figure out how to install turbo and rad and fans and plumbing in even less space than we had before...
