Midnight shadows worklog part 2
    my bearing is still fine use common sense & good placement & things are well
      There's no hole in the pulley Ill figure it out.
      Also yes as IMACH stated, I got me gaskets woohoo. Time to get busy
        Yeah Progress
          careful! my front valve cover is leaking after 10k with that kit! rear one is still ok tho
            its not the kit. its the pressure ratio from the engine. its not well designed to ventilate
              dude, its your front valve cover. 10 minutes and $20 will fix that..
              lol
              -Steve
              94' Protege < Worklog<SOLD!
              VF10 powered!
              262 Whp & 257 Wtq
              13.1@107
              '02 Suzuki Bandit 600s
                I plan on tightly sealing all the covers...especially the rear. Damn thing looks like such a pain to replace even while the motor is out of the car
                  there should be holes through the pulley large enough to get a socket through, so you can get on the heads of the 3 bolts holding it in place.
                  then there is a metal bracket on the back bolting to the block.
                  1990 Protege 4WD 5 Speed
                    lol
                    $20? maybe for people residing in the US lol, $20 doesn't even cover shipping for most items.
                      Here's a pic of the ps pump on the milli motor. As you can see there's no holes that go all the way through the pulley. The 4 holes only go half way through. Also this pulleu is plastic. The one on the mx3 motor has 2 huge holes so I don't see a problem getting that off
                        I have a cave man solution to your problem. Smash the facken pulley right off the power steering pump with a hammer, then un-bolt the pump. I would use a punch to pin-point my violence.
                        Then use the MX-3 power steering pump when you put the engine in your car.
                        Next problem, this one bores me.
                        (You would never be able to tell I worked flat rate at a auto recycler). LOL
                          I think you need to put the acessories back one with the belt and loosen that nut holding the pulley on then take your belt back off. or you could try and impact it off
                          "Who Dey"
                            Tried the belt technic. No go. I'll probably just use 2 dowel type pins and make it so I can use a pry bar to hold it from turning
                              i agree with IMACHU2 just smash the pulley off and use the one from the mx3
                              1994 Escort LX Wagon
                              2013 Hyundai Veloster Turbo
                              91 EGT - Junked May 2012
                                Hulk smash tiny man pulley
