Two go in and one comes out (Operation body swap)
    Originally posted by jinx View Post
    Work continues.. Here we have a BP distributor converted to BP CAS. The temp hold downs for the CAS cap are from my old cap. I will replace them when I get time to cut some steel up to weld on the cap.
    i thought this.. should you run it n/a on a basic map first to get the angle or does it not matter on the cap in coorelation with the bp dis half minus cap/rotor/button etc
    www.cardomain.com/id/bradsescort
      Flyrtle 6.0 Dynojet @ 15psi on BP26 ECU 229.31 whp / 229.95 ft-lb
      HPLogic Mustang Dyno @ 15psi on MS1 v3 226 whp / 195 ft-lb [HD Video]
      Soon to be powered by a Precision snail on crack...
      Add me on more pictures of my projects can be found there.
        meaning the angle voltage that is read by the CAS to the ecu/ms
        should you run it with it not welded up..(tape it)
        manually find the best spot.. then lock it down
        what are the benefits of having it to where you can manually fine tune this mechanically.. then go thru the maps and tune there as well.. might be useful to do, popped in my head when i read that and thought you would like to know.
        good idea
          Damn that's sexy
            looking good man cant wait til i start doing this to mine
              Where are those COP from? Looking great!
                ^ yota cop's
                and i was so tired earlier i didnt even see you dropped em in.. how do they sink down with that adaptor you made? just sortof rubbergromet in or is it more like a spark plug boot lock
                  Toyota Denso / 90080-19015
                    is that the j-spec contact number
                    we need more cops
                      are you running an ignitor to these COPs? I have an ignitor on my wasted spark set up, but I heard that you don't need an ignitor?
                        These have built in ignitors
                          dont taze me bro
                            It's done, I just need to pick up some better hardware for the cop bolt downs.
                                No updates yet besides me buying a spare BP to build up on the side in case the worst happens to the gtx block. Time to track down a bp4w head..
