manual boost controller
Mazda_Powered's 91 Protege LX
for you Bo lol-Jack
oh geez, not for a while haha. Broke til next month, but I can still keep busy til then...might as well make a list, right?
-solder broken wire @ back of trans (what sensor is this? reverse?)
-solder horn wire
-solder rad fan wires
-tape wires in engine bay from left fender harness
-install IC piping (off having lips rolled)
-mod BOV flange to fit properly then have welded
-mark outlet pipe for BOV recirc
-mark piping to have support brackets welded
-bolt in BOV, run vac line (waiting for more vac line)
-fabricate another outlet pipe & add barb
-fabricate upper mounts for intercooler
-weld flex pipe to DP (waiting for flex)
-bolt DP on (waiting for gasket)
-solder 4 wire plug for o2 sensor & connect + wire
then it'll see some reliable boost, here's what's left that won't affect the running condition for a good test drive lol
-mount rear plate lights
-mount battery tray
-disconnect engine harness so I can loom/heat tape the part that runs under the intake
-cut lower 1/2 off the Protege bumper
-stitch Stylus lower 1/2 on-Jack
did you have to give a cookie? just looking at that Im asking my lady to bake some lol
car looks ready to hit the road. almost there! I really cant wait to see what that bumper will look like completed on there.
Also the wire your talking about for reverse, There will be a white plug coming out of the trans very short in length and its located about to the right of your front motor mount when looking from the front of your car. is that what your talking about anyways? I cant find my other end to it tho haha. ne reverse lights here. I really need it tho for safety.Anyone knows what 9K rpm feels like? I do
93 Mercury Tracer SW
01 Honda S2000 Future Boost
haha thanks guys couldn't remember which was which. Looks like I'm not going to solder/repair the neutral sensor then lol. There was only 1/2" of wire showing from the sensor anyways so it would have been a PITA on the car haha.
today, not sure if I'll do much lol. Probably go around and check out misc stuff for safety and clean up certain things...
gotta order an outlet flange from napa too, and return my 2OD-2.5ID exhaust/intercooler reducer since I need 2.5OD doh!-Jack
Umm the sensor at the shift linkage is for reverse
1988 323 GT - B6T Powered
fk it, i'll just look for a replacement sensor then lol-Jack
cool, anyways today I pulled the engine harness out and taped/loomed it and re-installed it. Turned out alright, looks pretty much the same just with looming and the harness that runs behind the intake has heat tape as well.
I'll take a pic tomorrow, it's getting dark out now and my knees are sore from working on the car lol-Jack
Hmm maybe I'm wrong about the sensor lol my bad
meh, either way it'll get fixed lol just when is the question.-Jack
