Got the ECU in and plugged in
Got the bolts for the drive shaft and got it all bolted up, but not torqued.
Got the power steering pump swapped out and is all ready to hook up.
Got the brake reservoir tank installed again and ready to go.
Got speedometer cable swapped out for the right one.
Looked at the rear brake rotors, even beat on them with a BFH. I don't know how I'm going to get those things off for the new rotors.
install new brake calipers as soon as I can get those rotors swapped out
clean all those banjo fittings for the brakes and the power steering.
hook up wiring harness to engine and get all that hooked up.
get other cluster in dash and hooked up.
install new Walbro pump and get that out of the way
steel wool front axle splines and install axles
Source all fluids
Source all fluids
