its alot cleaner of a location then stock. at least once you have no battery, and no stock intake set up. the factory location looks cluttered with the fuse box up there. seemed to be a better idea to get it out of your eye sight as much. just had to cut off a few tabs so it would lay flat there.
~PaTricK~
-Current car's- ~ 92 Probe GT Turbo, 90 FE3 Turbo 626GT hatch, 97 KL mtx 626, 05 Mazda6, 09 Kia Sportage V6~
What are you driving?
yup didnt have to mod anything for the fuel lines to fit... but i am gunna eliminate how it goes from hardline, to rubber, to hard, to rubber again.. dumb ****in mazda lol
1992 MX-3 GS - KLZE 1997 Probe GT
Its not a BP05.... Its a BPOS... BIG PIECE OF ****
^^ yup they sure will.. but Ive been driving around for over a thousand miles with the kia axle on stock control arms... it binds around lefts turns if im going over 40 but otherwise im good... still gunna swap em out since i got em. but my underbody is so rusty im worried about snapping the bolts off...
LOL!!!! mapp gas is my friend... Im just being lazy right now... I need to get a different muffler and add another resonator... this dynomax sounds like SH!T
