My Protege KL Swap
    just read this thread and u will figure it out man.. i dont wanna sound like a dick but ive explained this 3 times in this thread.
    1992 MX-3 GS - KLZE
    1997 Probe GT
    Its not a BP05.... Its a BPOS... BIG PIECE OF ****
      Originally posted by dave0r View Post
      WTF
      i dont get it? i was told (From CP) to use the v6 MX3 axles ..so i brought the v6 26 spline LSD ones to suit my box and your know say its gona bind? on 1 side?
      totally confused now
      1 BP axle fits, if not too short
      the other BP is far to long, cant even bolt to hub to the strut?
      sorry for thread hax
      From what i gathered you need the mx3 lower control arms, the mx3 passenger axle and the kia bp drivers side axle.
      "Who Dey"
        lol jsut get mx3 v6 axles, mx3 v6 half shaft and mx3 v6 LCA's
        bolt everything up and you wont have any problems
        1996 V6 Escort
        1993 escort wagon DE/ZE hyrbid, ported heads, 5 lbs
          soo i tore apart the KLG4 I have laying around... 4 of the rod bearings look like this.. yikes..
          1992 MX-3 GS - KLZE
          1997 Probe GT
            Originally posted by pile_of_rd1 View Post
            when i had both mx3 axles in there my car felt like the wheel was gunna fall off when i got over 10mph... but now with the k-k-k-kia axle im good unless im tryna road race around some corners
            This describes the bf perfectly. Same exact issue. Mine only binds now if I corner hard to the right with the KIA bp axle. Mx3 axle made it vibrate like something was about to snap.
            '88 323 sedan, K-swapped..
              for sure! with the mx3 axle I hopped in was cruizing down the alley just fine.... get out on to the main street get over 10mph and I instantly was like "goin back home" lol
              It seems the more I drive it, the less it binds.. Im sure im fukkin something up
              1992 MX-3 GS - KLZE
              1997 Probe GT
                probably the mounts lol
                  Time for a new motor!!! yay. This thing smokes more than me and monoxidechild combined... its definitly gotten worse. like a quart every 30 miles.
                  1992 MX-3 GS - KLZE
                  1997 Probe GT
                    holy **** lol, thats brutal! my KL is at 232,000 km and it doesn't even smoke on start up that's the ONLY GOOD THING ABOUT MY ENGINE haha.
                      and the shifter broke today..... lol.
                      it broke when it was a BP, and it was welded... then it got swapped to a KL, and the KL shifter broke. damn.....
                      ~PaTricK~
                      -Current car's-
                      What are you driving?
                        cars cursed! mines the same way! haha
                        My baby 93' Protege Lx--R.I.P
                        New Baby 94' Protege Lx Black
                        91' Miata - SOLD
                        93' Protege LX new Project (no rust)!
                        Mods: Protege:
                        Engine: Fully built with wiseco 9:1 +1mm ceramic coated tops and molly skirts, M-tuned H beams, ACL Race rod and thrust bearings with King Mains, Arp Mains ,rod and head studs,3 lbs lightend crank, Everything is ballanced, spec stage 3 clutch,lightend flywheel, RX7 Afm, Fidanza Adj. cam gears, timing,Cut intake manifold from BPT323, exintake cam swap,full port and polished head 1mm stainless oversize valves, vf12/vj20Turbo, 3" custom full exhaust w/external wastegate,3" E-Cut, Eclipse crushed BOV , Fmic, Aem Urgo wideband, Autometer boost gauge, Magnaflo Muffler,batt relocated to trunk, slight wire tuck with engine bay fuse box under dash Bp26 ecu
                        Suspension: Energy Suspension rear trailing arms,Es Front Sway bar endlinks,Zx2 Front Sway Bar,El Sport w/bilstein mono tube struts and don't know what springs, Suspension Tequniques Rear Sway bar with Es endlinks,mx3 rear lower tie bar. corksport SS brakelines and clutch line.
                        Exterior: Adler Racing 16"s ,Mx6 Front lip,EGT Glass Sunroof,Edm Headlight & corners EGT side skirts,Gt Led wing, Led interior 3rd brake light
                        Audio: few things polk momo 6.5 components, VW Monsoon Front Componants with monsoon amp,alpine head unit
                          I thought that he was using the protege linkage, and stablizer bar or did he switch it out for the kl stuff?
                          "Who Dey"
                            yea its the K8 mx3 linkage... did a nice 2nd gear and the shifter fell through the floor... ****ty ass linkage design.
                            1992 MX-3 GS - KLZE
                            1997 Probe GT
                              yup... robbed my rust-free mx3's linkage last nite. the bp linkage is about a half inch shorter. I also had the knock sensor plugged into the wrong connector.. the mx3 knock sensor is next to the passenger mount instead of by the TB on the KL's.. I realized this at the yard yesterday.. the kl plugs in on opposite site and theres a connector on that side!!! switched plugs and gained like 15hp. lol
                              1992 MX-3 GS - KLZE
                              1997 Probe GT
                                im advertising now and have a fartcan!
                                1992 MX-3 GS - KLZE
                                1997 Probe GT
