Got slammed with a bunch of cage work---back to the protege finally! Starting to mount the bumper---it's a nice/tight fit with the IC/piping. He went with a jspec bumper. Tomorrow front skidplate...
AWD Turbo Protege Recce Rallycar
that bumper looks likes its missing some from the bottom. it doesnt cover the core support. is it supposed to be like that?1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
The angle I'm shooting at probably adds to it's "shortness". It does have a bunch of holes in the bottom for some kind of lip/attachment. It would make a nice place to mount a splitter---for this application the skidplate will hopefully tuck right up to it...sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
ahh im blind. thats funny that there is german on a japanese product.1994 Escort LX Wagon
Originally posted by MATT91GT View Postthat bumper looks likes its missing some from the bottom. it doesnt cover the core support. is it supposed to be like that?
Got the skidplate cut/fitted---biggest skidplate I've done yet, had to cover the IC piping. Comes uphill from the crossmember and then turns up in front of the piping. We ended up plating in the flat/bottom portion of the core support and slightly up the face for the front mounts. We should have about 3/4" to the oilpan and exhaust and about a 1/2" to the IC piping when mounted. Should be OK for the recce car---I hope...it's only 3/16"...I can't fit it back any further because of the IC piping on the drivers side and up any higher because of the passengers side...
In my experience with BP's and their radiators, they always crack under the overflow hose. (twice for me) A trusted member said once that moving that hose prevents the dreaded crack in that plastic radiator top cap. I upgraded to a radiator with metal caps so never tried his fix.
Just food for thought.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
You didn't use one of your big-honkin' skidplate/brace frames, did you?
Are there plans for that, or is this just gonna be hangin' in the breeze?
I'm kind of hoping to plan to get a good solid skidplate/brace pretty soon, in time for the winter ice shenanigans. The hope is to engage in some turbofication as well. Which is why this particular post has got me grinnin' and gigglin' like a little girl.
--sarge
Originally posted by pumer1904 View Postman something seems wrong with yor intercooler pipes hanging down way to low from the turbo to the intercooler
Originally posted by 1st Gen View PostIn my experience with BP's and their radiators, they always crack under the overflow hose. (twice for me) A trusted member said once that moving that hose prevents the dreaded crack in that plastic radiator top cap. I upgraded to a radiator with metal caps so never tried his fix.
Originally posted by SgtRauksauff View PostYou didn't use one of your big-honkin' skidplate/brace frames, did you?
--sarge
In that first pic above, you can see the IC pipe comes out turns and runs parallel to the ground---it probably pushs the hose up an 1/8" or more (which isn't ideal) and then maybe 1 1/2" after it passes the hose, the joint turns up 180 to the IC. If we piecut it (not enough space for even a bend) and shorten up one of the sections, we could get maybe that 1/2" I was talking about (out by the wheel/coupler, not under the radiator hose---we even flattened that tubing a bit to get more ground clearance)...I ended up going with a 3/16" plate instead of the 1/8" with a doubler in the impact zone like I normally would...sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
we "clearanced" the fender pocket a good 2 inches on the GTR build we just did but still had to lower the rad 1/2" to make it work"Discontent is the first necessity of progress."
