Boosted Escort Holset build
    Sub'd
      made a little progress today got axles out of the car. BFH and the right pry bar got the drivers side axle out. gtx motor is coming out to get forged rods and a new head gasket with arp head studs. stock bp-05 is going in with the holset. Hopefully this motor will take 14lbs with gtr ecu while i get the gtx motor built. The previous owner put in forged pistons with stock rods so that is why the pistons aren't getting replaced. This is my first time pulling a motor so i am going to take my time and mark wires and hoses so they get put back in the right place.Click image for larger version
      bp swapped escort lx, gtr ecu, gtr intake manifold, A code VAF, rx7 460cc injectors, ky clutch, holset hy35 turbo on 8lbs, 38mm tial wastegate, ramhorn manifold, full 3 inch ss exhaust, walbro 255 fuel pump
        Engine is in. Waterpump is leaking so new waterpump and timing belt going on.
          Ran into more problems pictures speak for themself.
            it wont fit turned around ? that looks fun.....lol... ill deffinatly be mounting mine facing the other way.....lol....
            92 protege lx-
            94 protege lx-
              why did you think it was a bright idea to put the EWG pointing forwards??? you have heaps of room from under the runners to push it off to the exhaust. & still keep a real radiator.
              PS resize the pic.
                I am probably going change the placement of the wastegate. That should be easy to get changed. On the previous setup i had the turbo facing the same way and if i flip the turbo the other way the compressor housing goes right up next to the radiator. It physically fits but i wont have any way to hook up the vaf. I think I will leave it the way it is and modify the coolant outlet to allow the radiator hose to go under it. what is the coolant outlet made out of aluminum?
                  yes sir!!! good ole unboltable aluminum goodness!! just make sure you clean the **** out of it before you try & have it welded.
                  Be minded coolant doesn't care about the angle of the piping
                    where can i buy aluminum pipe? I guess I need a 90 bend and some a straight piece.
                      ebay/ http://www.verociousmotorsports.com/
                        dont use that place they messed up my one and only order, charged way to much for shipping, and took an extra few days because they cant fill out the address correctly....
                        92 protege lx-
                        94 protege lx-
                          dude i had great results. call them. works easiest. the only place i could find with the AL bend to make the recirc for my BOV
                              Beautiful!
                                Sounds like a beast! I can't wait to get my car running...I just want to hear the motor run..its my first swap too, and I'm jumping into a steep learning curve with all the stuff I have for it.
                                Sub'd
                                1993 Ford Festiva - Fiona/b6 swap
                                1997 Ford Aspire - Peaspire/rescued restored and sold
                                1994 Ford Aspire - Kiazord/BPG5MR Swap
                                1999 Mazda 626 - exDD, sold
                                1997 Ford Aspire - Babyspire, stock low miles&clean
                                1994 Ford Aspire - Crustyspire, scrapped
                                2003 Chrysler T&C - grocery getter
