got everything put back on the car started it up and got oil pressure!!! tomorrow I'll get it inspected and get plates for it.
Boosted Escort Holset build
****ing awesome deal! glad to hear things worked out in the end.
subbin for soon to be updates---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
nice!!! what's your oil pressure like now? I think mine's around 55 cold start, 20 warm idle, and 30-40 cruising depending on rpm-Jack
Glad you got it sorted. Let's see some bids.AWD EGT BUILD http://www.clubprotege.com/forum/sho...-AWD-EGT-Build
anybody planning on deleting the iac without a stand alone ecu. Don't do it as it dies half the time when you come to a stop. I made a block off plate and everything only to revert back to the iac. Also my Turbo flange is warped so I guess I'll try two gaskets and if that doesn't work I'll have to get it milled down. spool up is slow with the leak.
well I drove it to work today with a b code vaf. b code vaf sucks. it goes rich super fast. vaf maxes out way to early and goes pig rich before boost. got home checked the mail and got my bip373 internal ignitor. The old ms1 internal ignitors used a vb921 which is weak and easily breaks if you use the wrong settings. I soldered in my new ignitor went outside and plugged it in. Car started right up. I need to work on tuning it now.
Sucks about the trans, but at least the rest sounds like it's going smoothly.
FYI I have my IAC blocked off on the BP26 ECU...idles great, no issues with it trying to die. Just have to free rev it for a minute before you drive it, and idle RPM is a bit low until she gets a bit warm...maybe 5 minutes.-Jack
Originally posted by Boosted Escort View Postanybody planning on deleting the iac without a stand alone ecu. Don't do it as it dies half the time when you come to a stop. I made a block off plate and everything only to revert back to the iac. Also my Turbo flange is warped so I guess I'll try two gaskets and if that doesn't work I'll have to get it milled down. spool up is slow with the leak.
