Its aliveee!!!!!
if you rebuild it. scrap cash for proper rods/pistons..... otherwise just buy another used BP & put in the proper sized injectors---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postif you rebuild it. scrap cash for proper rods/pistons..... otherwise just buy another used BP & put in the proper sized injectorsOriginally posted by miK3Pro View Postdamnn. just get a gtx ecu and injectors if you cant get MS on the next motor..
both great suggestions I would have made myself. Sorry to hear about the engine issues-Jack
i have no rush to fix it yet, since my licence will be suspended for a month (speeding ticket ) so far i have a gtx ecu afpr a b code n a r code vaf (to see witch one work best) gates belt walbro 255 gtx cams vj20 and fminc. still need aem wideband msd coil boost gauge (cause i didnt have one b4) at least 550cc injectors n if it comes across a gtr ecu if not ms2pnp. i plan on 10psi dd n 12-14psi when i need to, also controlled by the ms. but like i said i have like a month for it. i just dont know if i should go for ms2pnp or ms3.
started collecting some parts for my build here's what i got so far;
edt manifold
vj23
gates belt
r code vaf
es inserts
gtx cams
fpr
i dont know if i should go ms2pnp or aem. theere are any shops around that knows how to work with ms.
still to come;
gtr intake
cp pistons
manley rods
750 + injectors
walbro 255
cam gears
act clutch
wastegate
wideband
boost gauge
kia trannyLast edited by 323 mazda; 05-09-2012, 03:17 PM.
done that before!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
WOW lol put that on display!!-Jack
